C
Codeseven
When recording drums is it generally the goal to subtly add Eq and Effects, ie add more lows to the bass or is it to subtract from the sounds, ie lows from the cymbals to get the desired sound? Once your kit is correctly tuned and your room is correct acoustically shouldn't, generally speaking, the goal be to capture the great sound of your kit and only make subtle use of EQ and Effects?
, I add or subtract as much as I need to get the mix to sit well together.
