wallystripes
Hahaha I know waveforms represent audio
Thanks Jimmy! I will try this next time.
Thanks Jimmy! I will try this next time.I can see sliding a track to adjust the phase/timing when using multiple mics at *slightly* different distances, or a mic & DI....
...but IMHO...if you are setting up a room mic, then you kinda defeat the purpose if you align it with the close mic track.
The room mic IS about the delay and the distance and the ambiance. If you push it up to be in sync with the close mic, you lose all that flavor.
Also...at the greater distances used for a room mic, there are not going to be too many phase cancellation issues by leaving the tracks as they are "apart, rather then aligning them exactly together.
...cool things can happen by using two mics, at alternate placements from the source, then aligning in DAW. And like I said, not always, and is probably not the best starting point.
FM you could ..... oh never mind. I forgot that the minister won't let you purchase a ribbon microphone.
Though that would give you the capture of the amp side and the room side from the microphone.
You're not trying to simulate reverb by having the distant mic x milliseconds farther away than the near mic. You just want a pleasing mix of clean/close and some "air" from the room.
Yup...that's been my recipe for guitar tracks for the last 2-3 year now.
I put my Fat Head ribbon about 12" away from the grill...the back picks up the room. Sometimes I don't want the room so I drop a "tent" over the whole rig.
Still just curious, and not knowing, perchance throw in the possibility that if said walls and stuff's reflections are within the Haas zone..?...Turns out that the room that the iso box sits in, which is concrete and brick room filled with a lot of random junk, sounds good. It sounds good to my ear when I'm in there playing and I've heard it sound good recorded when I did a close-mic/room-mic comparison between my treated room and my junk room. Junk room was lively.
The natural scattered sound reflections in the junk room sound like they're doing a nice thing. So I guess it looks like my ugly eq is either the mic eq, or the room eq ..
Hey moresound, what is the ribbon mic you use?
Ok, MXL R441 will probably be on my list. Any other decent reibbn mic for around $150?
