P
Powerbastard
A little background:
I write/record instrumental metal and use Cubase. I use Beatcraft to create drums and when i import to cubase the file is nice and loud and doesn't clip, but i lower the track volume to -1.0 just to give me some room. When i record guitars, the wav is clipping at around +2db so i bring em down using the track levels. My final mixes ride between -1.0db and 0.0db, so they're not clipping. There are usually one or two leads or melodies that don't seem to sit right in the mix so i normalize to 100% and that seems to smooth things out.
I always put new songs on my ipod and listen to em in my car so i can see if anything sticks out in the mix.
What i don't understand, and would like to change, is why the volume level of my tracks are so much lower than other songs on my ipod. Granted, these other songs were recorded in fancy studios by professionals, but isn't one non-clipping, 0db-max recording the same as the next? I've spent hours reading about compressors, limiters, mastering....and no matter how i adjust things, any increase in volume i am able to achieve always results in clipping. The result is no different than if i just raise the output level on the mixer in Cubase: Higher volume and mega-clipping.
Without re-explaining how compressors work and what the different knobs do, can anyone give me any advice on how to get a louder finished product? At this point i'd welcome a logical, easy-to-understand explanation even if the solution isn't something i am equipped/qualified to do myself! Also, i've imported a high-dollar professional recording, and a song my band recorded at a local studio into Cubase to compare volume levels and had to raise my recording by 3db to get it about even with those other two.
Any insight would be MASSIVELY appreciated!!!
Here's a link to my tunes, for reference
POWERBASTARD's sounds on SoundCloud - Create, record and share your sounds for free
