J
jokerone
Guest
I have VST drums and I want them louder in the mix, but the show they clipping in Cubase.
Any suggestions?
thanks.
Any suggestions?
thanks.
turn everything else down
epthwhat i do at every level is from recording i set peak levels to around the -12db/-9db mark to allow head room while recording, while mixing i mix to around the -6db mark then when mastering i bring the level all the way up to around -0.1db mark. this allows all the head room you would want and avoids clipping.
The best solution for this problem is simply turning everything else down. it's not that complicated really.
You will have the rest of the tracks too loud, and also your monitoring volume will be too low.
G
I can't believe "turn everything else down" has to be explained. Well, I can believe it, but it's pretty sad.![]()
You're comparing your un-mastered mix to mastered mixes. Apples and oranges. The mixing stage is not the stage where you should be worrying about volume. That happens after you're happy with your mix and take it to the "mastering" level.
Yes, you should be worrying about the mix and balance of all the tracks. That's what mixing IS, to a great extent. I'm talking about overall volume. It doesn't matter how low the overall mix is during the mixing stage.You shouldn't be worrying about volume, but you should be worrying about the mix and balance of all the tracks. And, at least in my opinion, getting the right balance between the tracks is not a mastering issue, it's a mixing issue.
