R
		rockironwebb
senior newbie caveman
Just went on a reading rampage and am confused again, surprise, surprise.  I was going to tinker around with my drum levels again just to see if I could get some better sound, they are not bad now, but I've learned that not bad now can end up being shit after some adjustments. I am using an ALESIS multimix 16 firewire mixer and recording into mixcraft5 and sometimes ACID pro7. Now at the mixer, do I adjust gain to just below clipping? I had done it so when each channel was set for pfl, the little led vu meter would peak around "0". I just read several things about setting the gain on each channel till it clips, and then backing off a little. If this is proper, where does unity come in to play? Hopefully you guys aren't sick of my caveman ways. How would you go about setting up each channel. I have read so much by now that I am more confused. My goal is to get get the best possible sound into my DAW.
