Yeah this, I don't know why anyone over thinks it.
If you track and you clip at any point, then the gain is to high.
The fact that you don't reach
digital clipping means nothing if you're running the analog chain far over spec...
And with digital, the signal doesn't change as you approach zero. It's not like tape saturation or analog distortion.
After conversion, yes. But before conversion is where all the damage is going to happen.
In digital, it's the same till you hit zero, and then it's shit. I'm not suggesting anyone record as hot as possible. I'm just saying that I don't pay any attention to the numbers. I just don't clip.
If your converters are calibrated to -18dBFS (= line level), then by the time you're even in the same zip code as "clipping" you're
overloading the analog components by around 300%. Some (usually freakishly expensive) gear can handle that sort of voltage without too much damage. Much of the popular stuff out there can't come close -- Although some of it might be perfectly usable around 'normal' voltage (M-Audio's DMP3 is the perfect example of a perfectly decent sounding preamp that turns to complete crap quickly when pushed even a little).
The whole point of digital - especially with 24-bit digital - is to be able to actually use
normal levels with incredibly
high resolution. I don't like watching numbers much myself -- But "as long as I'm not clipping" during tracking is (A) wholly unnecessary and (B) almost without exception, just plain bad sounding by comparison (assuming the signal is "somewhere short of clipping").
I don't mean to drone on about it (which is why I ended up writing that blog article in the first place - because I droned on about it far too often), but after dozens and dozens and dozens (they keep coming in) of messages from people - some of whom have been struggling for
years trying to make decent quality recordings - suddenly
hugely improved that quality just from using "normal" tracking levels... It still blows my mind that anyone ever thought anything different in the first place.
YES -
During mixing and processing, those internal levels don't really make a difference (except with many plugs that are designed to emulate analog gear). But you only get a chance to get a clean signal with a good SNR once.
