D
DarknessRecords
What accoustic foam do u recomend?
I am by no means an acoustics expert, in fact I know very little about the subject.
Why then do you endlessly seem to argue in favor of foam in every thread that pops up if you know very little about the subject of acoustics?
Are you just trying to ease your own conscience about using foam...or just wanting to play devil's advocate in favor of it for the sake of initiating a debate...?![]()
No, he's not. He's asking a good (although kind of vague and misguided question), that will ultimately yield him some favorable results if he's smart enough to listen to his fellow forum members who've done their research and who speak from experience.DarknessRecords, you are setting your self up for a lot of abuse from self-appointed "experts"
No he's not. For one thing, I don't see anything in either of the two posts above yours that remotely qualifies as "abuse."DarknessRecords, you are setting your self up for a lot of abuse...
Is a vintage U87 a better mic than an SM57? In most cases, yes, but that doesn't mean that a lot or great records weren't cut on the lowly SM57.
Are there room treatments better than acoustic foam? In most cases, yes, but that doesn't mean that acoustic foam is worthless...
Ok, I'll put my opinion in a simple form. For the price of foam, you can build yourself panels that are proven to outperform foam in every way. Why would you say that foam is a good idea to someone who does not have that information yet. Yes I use foam in limited instances, but I would never defend it by saying that people give it a bad rep and you should go with it. And to even suggest that egg cartons are better than nothing, is an expression (IMO) that you have not a clue.
There is a lot of knee-jerk reaction against acoustic foam around here, and as is typical with Internet boards, I imagine a lot of it comes from people who really don't know their ass from a hole in the ground.
I stated, "I am by no means an acoustics expert, in fact I know very little about the subject."
Here we go again.... A very common problem for home/amatuer studios is 'boxy' muddy sound, which is basically an over-abundance of low frequencies. What does foam do? It captures HIGH frequencies. So, in a place where you have too many lows, you're removing highs. End result is a room with an even WORSE low:high freq response ratio - it makes your problem even worse. OC-703/705, rockwool, etc. trap lows 100x better than auralex and will flatten the freq response of your room. Start with that, it's cheaper than auralex anyway, so I never understand what the debate is all about. It's physics, not speculation and myth. Sure, pro studios have some foam. They also have 10x the better stuff.
