PDP
There once was a note
Anyone know the cause of one note bass ? I've read how it can be fixed, but I'm not thrilled about the solution (cutting just that exact freq with an eq) any other suggestions on avoiding the dreaded "one note bass".
Are you really having a problem with this? Don't chase ghosts that aren't there.
What is "one note bass" ?Anyone know the cause of one note bass ?
It's when one bass note jumps out more than others. On my bass setup, it's usually between A and D on the E string.
Like a B (7th fret) on the E is boomy, but the same B (2nd fret) on the A is fine.
Cant help wonder if it effects the tone of the other notes/negativelyWhy aren't you thrilled with the solution? Cutting the problem frequency will be the simplest, and probably most effective way to deal with it.
Good question which is why I thought I'd just see what other guys say about it. Its hard to know whether its the recording, or just the speakers in a particular room that create the trouble.Are you really having a problem with this? Don't chase ghosts that aren't there.
You can get "one note bass" on any bass instrument, acoustic, electric, synthisizer.What is "one note bass" ?
The Katz method uses a Q of 12 so that's a pretty narrow notch filter.
Thanks, Yeah I've seen that method demonstrated and it does work. Thanks for pointing out that its build-up, rather than some mysterious bass problem.
Thanks for all the replies, mastering compression helps even out the subs too, but I like a booming bass in alot of stuff, its only a problem when a song is pumping away in a club (or system with heavy sub woofer) and this wopping sub note booms out. Most pro stuff is very even, (although I've heard it sometimes) it may be that I know very little about Mastering, but any way to even out a sound without compression is worth knowing to me.
I liken this to something similar a few octaves up; I have had mixes sound acceptably balanced on my system but sound out of whack in the upper bass on some 'hi fi's, where a ref disk didn't not.
The difference- They were more scooped or controlled in the region.
My take on this is that while a flat(er) low distortion system is at the same time a more accurate and neutral platform, it is also in some ways more forgiving. A bit of build up' coming off as 'character in a mix can collide with these various humps' in rather interesting ways.
