Would you be able to post a pic of your drum kit mic'ed up?
Not now, but I could set up everything next weekend and take a photo. Please, take a look at description I would provide bellow and tell me if you can picture the scenario
Ohh try flipping the phase on one of your overheads. Or even better, move the mics further apart. The actual drums don't sound all that bad.
I guess my mixer doesn't have the change phase feature. Would I need a "switch phase adapter" or are there other ways of doing it? I can definitely try to move them futher apart, but then overhead mics would be in the edge of my cymbals, right?
How many mics did you use? Where were they placed?
8 in total. I'll try to describe their positions here:
1) Bass Drum - Beta52 half away from front-head hole which is located in the center
2) Snare - sm57 two fingers above and inside the rim and pointed to the center of the snare
3) Rack tom - I guess for this recording I've used 1 mic for two rack toms which I put in the middle of them, but today I would use only one rack tom in the kit with beta57 about 10cm above/over and pointed to the center
4) Floor tom - similar to rack tom, sm58 about 10cm above/over and pointed to the center
5) overhead on the right - behringer c2 around 50 cm above crash cymbal, pointed down, off-centered (I would say in the middle of the way) in direction of hi-hat
6) overhead on the left - behringer c2 around 50 cm above crash cymbal, pointed down, off-centered (I would say in the middle of the way) in direction of ride cymbal. Try my best to put in paralel with overhead on the right
7 and 8) room mics - 2x behringer c1: one in the left, other in the right, in front of drum kit. Imagine like an equilateral triangle between the drummer and both mics distant something around 2-2.5m from each other
If not clear, please, feel free to ask
