M
MoBuc
Hi all. Just installed Tascam US-1800 USB Audio Interface. I had 2 goals:- Replace my EMU 1212m PCI Audio Card with I/O Pre-Amp & greater features;
- Maintain or improve my current DAW (Mostly 'In Box') options.
To do the 2 above, I should be able to continue using only 1 Snd Crd. I've disabled my on-board MS Wavetable/AC 97 long ago with no problems. Now with the US-1800, I cannot record Web streams or 3rd party Audio into my Sequencer/Recorder SW.
Q: How can I use or configure, the US-1800 to send Browser streams into 'In Box' Recording Gear?
Ex. Previously, I could Record my Webinar's Audio into either PowerTracks Pro 2011 (ASIO Drvr) or Audacity (MME Drvr). If needed, I could then use Fx within either Mixer/Recorder by send/record from 1 to the other. No cabling or ASIO/MME changes required.
So far, I must use at least 2-Snd Crds/Drivers to achieve what I did with my 1212m alone. I now have Cubase LE5 which came w/the US-1800 but so far, no solution without keeping 2 sound cards active. Any ideas is greatly appreciated.
