Y
youaretheblood
Hi I really need some help, I've looked everywhere for an answer to this.
I'm trying to create a project with all of the loops from my songs in it. My set consists of lots of different loops that slowly get layered, one on top of the other.
Now I've seen another post on this forum (maybe called "how do you save your setlist) however this has not helped me.
The main problem being that all my songs are in different tempos and time signatures. I know that it's possible to rename the clips in the master scenes to change the tempo, but if I do this, it will launch all the clips that are on the same scene (when I usually start off with just needing one). A work around to this is putting the next clip in the next row down (but to be able to overlap it with the previous clip it also needs to be in the next scene) so by doing this my set appears on ableton as a really long diagonal line made up of clips.
Is there any way that I can make it so, that I can change tempos without having to have each clip in a different row and scene?
