Shadow_7
What would I need this for?
Also yes I was going to get a shockmount too, but seems I forgot to list it.
If you use external preamps and your interface has it's own preamps, many will let you bypass their preamps with the TRS connection for INPUT, but NOT the XLR connection. And some interfaces like my Delta 44 only have TRS inputs. And some preamps like the DMP3 an Rane 1? only have TRS outputs. Various reasons depending on the actual gear in use. Just different ends to basically the same wire (XLR / TRS). But some very specific uses internally depending on the gear in use. And other needs as TRS will add that pop noise when plugging/unplugging a live system and XLR wont.
