JG96
Active member
View attachment Sunday Night Take Two 3.mp3 My band has been playing this song for a while and we recorded it recently. Could I get some advice on what to do to make it sound better? Btw the song starts at 15 seconds or so.
The drums were actually tuned right before recording. The problem was it is recorded with just two condensers and the snare is probably the weakest link in this set in general so there was no real way to eq it to make it sound better. I recorded the bass direct, usually I play through a gallien Krueger rig with the bass rolled off a bit, i think ill fix that now.Cool sound. At first it kind of sounds like Phish, then it morphs into a 60's Rock Hit. It morphs again into alternative rock. Wow that's quite a sound. Anyway, on the mix. Were the drums tuned? It doesn't sound like it. Drums should always be tuned before recording. Specifically the toms that pop out in this mix. The snare is a bit boxy. Some EQ and Compression might fix that. I'm not too crazy about the bass tone. It's a bit muddy. Again, EQ could fix that. Everything else is pretty good. Good job.
Hi,
I listened to both mixes...they both seem narrow to me, with little or no panning, and to me that is the lowest hanging fruit. Pan a few of the elements of the mix out away from center and you will immediately have a better mix. Typically people leave vocals and bass in the center, and kick and snare also, but toms, hi hats, cymbals, guitars, and other elements can go out in the stereo space. Try to keep things balanced. This has a couple of benefits IMHO, first it gets all those other things out from on top of the rhythm section and the lead vocal. You might find that your bass and drums immediately sound better if they have some room to breathe. Also, spreading those things out will just make the mix sound bigger and more modern. Again, this is just my opinion, but I think a lot of people would probably agree.
In your second mix, the bass sounds a little hyped in a weird way. If it were me, I'd just try to get a good, clean, natural sounding recording of each instrument. Don't EQ too much, because that's where you start getting weird buildups and strange mixes that don't translate well on all different kinds of listening environments. Spend most of your time up front getting a great recording, choosing the right mics, experimenting with mic placements, getting a good clean direct bass sound, etc. Then the mix is just mostly a matter of levels, panning, and some light compression to even things out. That's my advice, and that plus $24.95 will buy you a nice mic cable
You are on the right track, best of luck!
Dave DeWhitt
SoundClick artist: Dave DeWhitt - page with MP3 music downloads
