Myriad_Rocker
Well, I think I've finally come to a point where I can begin to treat and prepare my new room. I don't have a desk yet. I plan on building one. I also don't have a recording computer or interface anymore. I sold my old ones with intentions to upgrade and that's next after I set a good plan for the treatment. My hope is to get my main areas of concern and then fine tune treatment when I can test it properly.
Attached is a Google SketchUp of my mix room. A couple of things of note...
- The small thing on the wall is the thermostat. That can't be moved or covered so I'll have to build any treatment around it.
- The door closest to the thermostat is a closet
- The second door is the door to the bathroom. I was thinking of building around it and making my treatment (wood slats if needed) on hinges to be able to get through it.
- I put a single simple light in the center of the room with the intent to build a cloud and put recessed lighting in the cloud
I welcome treatment suggestions or plans. I'm hoping to buy all my wood (for slats, treatment framing, etc) and OC703 soon. One particular point I'm wondering is if I should go with hanging bass traps in the corners or super chunks.
I've done quite a bit of research on the topic of building and some on actual treatment (I have Rod's book and have read it a few times). I've been out of the game a while (because I just moved into my new house that was built) so I'm needing some refreshing. Another point that I'd like some direction on is where and when it is appropriate to use wood slats, etc. I've looked at quite a few of John Sayers' Sketchup drawings and plenty of pictures.
I can take actual pictures of the room if necessary. I'm not really worried too much about sound proofing. I'll be tracking in the room across the way from the bathroom (it's a Jack & Jill bath). But I'm a hobby recorder and I don't really do it on a regular basis. My nearest neighbor is quite far away. Two of the walls of the room are outside walls, which are brick. The area of the house we sleep in is on the opposite end, but that doesn't really matter.
Hope I didn't miss anything! Would sure appreciate some help/direction to get me going. I'm itching to get in this room and start using it but I know I have a lot of work ahead of me first.
I started to have my builder double up on drywall and do a staggered stud system for the room but I was already 30k deep on having to put in my own money on the house. I don't record often enough to worry that much about sound proofing. So...I elected not to do that. Just FYI.
I have a SketchUp file available...I couldn't upload here.
Alright, here's my drawing. Forgive my lack of SketchUp skills.
On the side treatment, I'm thinking of making those to where they're not fixed...so I can move them around if I need to. On that one bass trap, I'm thinking of doing the same thing. It'll be obvious which one I'm talking about once you see it.
I'm also open to other suggestions. I'm thinking of more bass trapping where the wall meets the ceiling on the back wall. That's why it's shorter. Thoughts?
Also, I know the front wall is "missing". I'm going to mount a 42" LCD there and treat it exactly like the back wall.
I'm also putting in a cloud about as far back as the angled side treatments go.
I would REALLY REALLY appreciate some thoughts, input, or something from this. I've toiled and toiled and worked hard on this drawing.
