M
mikedavid00
Hi,
I need help with vocals. I realize I need the sound to sit in the mix.
My issue is that most online resources are for rock and pop. Where they talk about using very little compression and re-verb.
I'm sure Rap has it's own specific requirements when recording vocals and having it sit in the mix. I don't want organic sounding roots hip hop, I want hot, commercial style sound.
I need to know compression ratio's, eq, and generally how to process vocals when recording hip hop.
Thanks for any help.
... now that is done get heaphones so no sound is captured of ur music than after that record a bit without any thing just silent record... if ur using audition capture the sound profile... record ur vocals and apply the noise reduction...
now u will see that u have good enough dry track now for the compression... since its rap... open up parametric eq ... cut of the frequencies below 60hz mind you this is only for ur vocals ...and after that cut off frequencies above atleast 18khz apply
