LUNE
...a pieds joints
Hi,
So I've read a bit about peoples perspectives on running the +9 (or higher) range of tapes (Q 499 / SM-900 / ATR) with the 'semi-pro' format tape decks (1/2" 8-track, or 1/4" half track) and why its not always possible or advantageous.
What ARE the 'semi-pro' half-track decks that could take it as is or with minor modification?
quoting some post from EVM1024: "There is a mod (increase the bias coupling cap value from 100 pF to 180 pF) that will allow the MS-16 to bias properly." I presume this would work out for the 52 as well? what about the 42?
And the Otari 5050 series? (I don't know much of the differences between the ii, iii etc.)
I'm just trying to get an idea of what machines could be biased for the +9 tapes and would have a chance of holding up to the added strain of the thicker tape.
anyone have any experience with that?
) and so I experimented with a couple other varieties and found one that works best for what I'm doing. I still switch between the three varieties of 1/2" tape that I have in my closet, because I know them each well and I know what I can expect from each of them.
