I don't hear anything else that needs improving about it. This one is going on my iPod.
Could you give a detailed explanation or play by play of how you mixed this song, what effects were used, etc.?
Thanks D. A lot of it is trial and error ... and learning from mistakes.
I'll quickly give you a run down of what I've got on each channel, but going into eq settings would be too confusing.
Drums: Mentioned in above post
Bass: Real - only has another Boost11 limiter on it. That's it. Panned center.
Elec git: Line 6 Pod XT source - direct in. Panned far left. No plug in the track itself, but is Aux bussed to a delay panned far right that answers the stabs.
Piano: Ivory plug in that comes with Sonar PE ... panned right ... nothing but the plug itself in the channel. No eq on it either.
Organ:
Native Instruments B4II 16' setting. Again, no compression or eq. Panned far right.
Vibraphone: Panned dead center ... low end rolled off.
Strings: 4 channels panned all over the place to fill the space.
Background vocals: 6 channels of me doing various harmonies with different vocal timbres. They're all the same notes, but I mixed up the falsetto parts and the regular voice parts of the same notes and panned them to opposite sides ... making certain to keep a balance of regular voices blended with falsetto so that the submix (which each individual channel is sent to) didn't lean too far one in any direction. The submix was hammered with the Boost Limiter to really squash the blend all tight and together. Then I rolled off the highs and lows so that they stand behind the lead vocalist -- not frequency compete for notice in the mix. I then aux bussed the submix and added subtle modulation effect to thicken and enrich overall.
Nyah Nyah: Eight channels sent to another submix and given similar treatment as the bgv's ... minus the modulation ... because I wanted each channel to be more distinct, w/ less mushing together. (Mush is a technical term)
Lead vocal: Panned center and has three plugs on it -- A Waves Rennaisance Compressor sent to a VC64 Vocal channel (included in Sonar) to the Boost 11 limiter (also included in Sonar). The delay is in the VC 64 ... and the other two are used to level the vocal in the pocket.
Main Buss: The Boost 11 again ... dialed in VERY lightly just to trim the peaks.
I hope this helps explain a little better. If you've any specific questions, I'd be happy to answer.
Best,
Kev-
