sweetbeats
Reel deep thoughts...
Thinking ahead to the cabling to interface my Ampex MM-1000 and my Soundtracs MX desk...and even further out to when the Ampex is setup for 2" 16-track operation.
The snake from the Ampex to the mixer is a no brainer...I have a 16' 16-channel TRS-TRS snake I made some time ago...the TRS plugs at one end of the snake will be replaced with XLR plugs...Ampex XLR outputs 1~16 to mixer line inputs 17~32...done.
My question is about the cabling to interface the mixer outs to the Ampex. I'm going to be using the Soundtracs' 8 group outputs, but I want each of those group outs to interface with two tape machine inputs (just like you'd do when using something like a Tascam M-300 series mixer to an 8-track...only think 8 groups to 16-tracks instead of 4 groups to 8-tracks).
My crux...I want to just use an 8-channel snake and daisy-chain the connectors at the tape machine rather than use 16-channel snake cable...so what'll happen, for instance, is channel 1 of the snake will go from the mixer group 1 output to the tape machine input 1 and then in series to input 9 (so inside the plug connected to the tape machine input 1 jack will be two sets of 3-conductor cable...the cable coming from the mixer and the cable continuing on up to the plug for input jack 9.
Does that make sense? Any negative issue in doing this?
Yes, the transformer is to get a true balanced output. (I think you mentioned once that the Ampex also had provision for a transformer balanced input. -- just as an aside, the Otari I have has a transformer balanced input option, and the dbx 180 has a transformer output option, in fact Jensen still lists the transformer --- JT-123DBX, the Dolby 36x series frames have transformer balanced i/o as well.)
