SouthSIDE Glen
independentrecording.net
One thing that I wonder about when working with global track adjustments in any DAW...like what if you pooch the track settings and you can't UNDO them back...you kinda mess up the whole track, whereas with the Objects...it's always minimized to individual elements rather than the whole track.
This is what's fascinating (to me, anyway);is just how many different permutations there can be in technique. You two guys have here brought up two different situations that I personally very rarely have to deal with because of my own homegrown methods. At the same time, I'm sure the way I do things has its own weaknesses that you guys can regularly avoid having to deal with.When I want the level changes to happen before the inserted compressor I slice up the block and adjust there, driving the signal into the compression. When I want to adjust the level after the compressor I use fader automation. The first is "correction" and the second is "expression".
In the first instance, I actually only very rarely apply global compression to the entire track in the DAW; I tend to do like you say miro, and attack the level issues via spot waveform editing and fader automation. I do often compress "globally" during tracking using the outboard box in order to get a good character on the track (and a bit to keep levels sane too, but I probably would not do that if I didn't really like the sound of my outboard compressor), but once in the box, the amount of compression I use is actually minimal (unless I'm going for a special unnatural effect.)
I do apply global EQ often in many different forms, but "undoing" that if an actual undo is unavailable for some reason is usually as easy as just applying new EQ to get the new sound I want. But rarely is that kind of undo even necessary in EQ, because A) I can usually work with/around whatever I have, and Bee) I try to keep my "saves" at strategic points to ensure I can go back if I need to.
And as I tend to address localized level problems with spot editing and/or automation instead of insert processing like Boulder describes, the potential issue of fading around edited or processed insert points never arises; it's all automatically just part of the automation curve or of he spot waveform editing.
Yet your methods have their advantages too. It's just really interesting that the more one works with others, the more one sees how others have developed their own favorite techniques that are equally valid, with each introducing their own set of strengths and weaknesses. There is no one right way. Which is why I've started to adapt some of Jay's methods and add them to my own - and vice versa. I'll use his divide and conquer when it's best to do so and my own "home" set of methods when they seem more fit. And he's doing the same with learning some new tricks (for him) from me.It'll only make us both better.
G.
