FunkDaddy
re worked runaway. please have a listen at this new mix. am i headed in the right direction? can yall see improvements? and what still needs to be improved?
http://www.soundclick.com/dhsh
Didn't catch the first mix...
Could do with a better drummer, very sloppy. That's the first thing that takes the whole thing down a notch for me.
The drum sound is pretty bad too. Barely hear any kick drum. The snare drum sounds like a cardboard box. Toms could use more punch. Only thing I'm digging is the cymbals and hi-hats. I understand you're bouncing everything down before it gets to your interface but does the mixer you're using have any insert effects on it? Metal drums = compressed to hell and back and then compressed some more. But they all need their own levels/settings of compression, simply compressing the drum bus won't get the right effect.
The vocals don't really sit in the mix, they sound "on top" of the entire song.
The whole mix just needs more tightness, more "in your face". The guitars sound tinny and lifeless. It sounds like it was recorded in a garage through one mic and then vocals added over it.
