TelePaul
J to the R O C
Hey all,
Can anybody explain why there are two outputs from the switch in the pic below (or why the one 'out' is wired across two terminals?)
[/IMG]
The reason I ask is that the switch I'm using right now has one obvious out and also has what appears to be an earth which isn't attached to a terminal on the switch, but is wired to the back of the volume pot nonetheless. I'm wondering where this particular wire would go if I used the five-way switch above?
That's a very confusing answer, and somehow I'd imagine incorrect. The switch is an example of redundancy. It's a two-pole five position switch (or three position for the older Fender stuff). On the really old Fender stuff, one side selects which pickup(s) you get, and and the other side selects which tone control you get. If someone had thought about it for longer than ten seconds, you could have fed the pickup through the tone control to the switch, and had one side unused. But I guess this way gives you more options.
But why didn't Leo just wire each pickup to a tone control and then on to the switch, going out to a master volume control?
