B
BLP
I plan on getting a Neumann TLM 102 a few weeks for now. Currently my audio interface is a TC Electronic Desktop Konnekt 6. If I use this to run my mic to my computer will I be loosing any quality?
I want to know how to get the best quality out of the TLM 102 or will the mic pres in the Konnekt 6 work well enough as is.
Here is description
Desktop Konnekt 6 lets you instantly record, musical instruments and vocals into your Mac or PC. With Scene select you can easily access three independent scenes or "setups". The three default presets are for Microphone and guitar, two guitars/basses, and a Stereo line signal. You also get the high Resolution meter that gives you precise information to Monitor the level of the Input signal and if you're near clipping. You can also choose to use the meter for mastering purposes. When it comes to quality of inputs Desktop Konnekt has no compromises and offers IMPACT mic pre, Hi-Z guitar/Line Inputs, Headphone Output and 2 balanced outputs for powered or non powered speaker monitors. Perfect to let you instantly add a reverb using M40 Studio Reverb or to take along with your Notebook for portable Recording sessions, make the Desktop Konnekt 6 your choice now.-Cubase LE4 included-FireWire 1394, Bus powered-24-bit/192 KHz sampling rate-Monitor Control-Big volume control-High resolution meter-Tracking reverb level control-Direct monitor control with Input/DAW control-DIM Switch for convenient speaker dimming-Instant scene recall-Separate headphone level control-IMPACT Mic preamp and I/O-48v phantom power-Inputs: mic + instr / instr + instr / stereo line-Balanced stereo outputs-True Hi-Z guitar inputs known from TC's high-end guitar processors-Headphone out with separate level control and separate source-M40 Studio Reverb powered by AlgoFlex-Studio Sound reverb based on Hardware technology-Hall, Room and Plate algorithms-Powered by AlgoFlex - a new High Definition TC technology that enables hardware quality and predictability to be ported to native software.-Part of monitor mix and included as VST/AU compatible plug-ins
Here is description
