presto5
Is fret buzz something all guitars have or can it be fully fixed....I record with a very clean sound sometimes using one note strikes on the low E and A strings...Oh and using a Strat model guitar..Anyone
Is fret buzz something all guitars have or can it be fully fixed....I record with a very clean sound sometimes using one note strikes on the low E and A strings...Oh and using a Strat model guitar..Anyone![]()
They can all be fixed.
What bridge do you have. On my Strat you can raise the saddles on the bridge for individual strings. If you cannot do this, check that the frets are level. If level, adjust the truss rod to raise the strings.
Another option is to file all the frets down.
Its a Wilkinson bridge on a custom Strat style guitar..everything is new but the pickgaurd and pickups..
file the metal part of the frets or the wood?
Also, like the person above yelling at you...
This is one of those situations that a good tech would fix in a few minutes but an untrained hand can make worse. As I am fond of saying here you cannot make a decision on what to do until you have given all the information so with the exception of KoP's post in bold ignore all so far. Much of it is not just ill considered it's plain wrong.
. .they can all be fixed.
What bridge do you have. On my strat you can raise the saddles on the bridge for individual strings. If you cannot do this, check that the frets are level. If level, adjust the truss rod to raise the strings.
another option is to file all the frets down.
I pride myself in trying to help people where I can.
I did underestimate the skill level of the OP. But what did I say that was wrong?
Hey Mutt, you got me.
You can loosen the truss rod to raise strings (depending on the truss rod), you can also adjust the frets. I was summarising what could be done IF YOU KNEW WHAT YOU WERE DOING.
My bad.
alright ..I brought my Mexi Strat to this guy down the street who is a "pro" has his own shop. "can you fix this buzz? I dont have an allen wrench?" Come back 20 min later and he tells me my neck is fucked ..broke on the inside "trusss washer is loose" upsells me a neck from usa custom...beautiful. still buzzing. " oh man your strat saddles are crap! Now they are buzzing. You need these! ( shoulda cued in right there right) stupid me... Oh man your neck pocket is warped...you need a new body...bought a nice one from Warmoth ...beautiful..still a prob...Now I realize I shoulda got a second opinion on my Mexy cus this guy doesn`t know shit but how to turn a screwdriver...and by now I coulda had my buzzing Mexy intact along with a brand new guitar.![]()
My bad.
My bad.
your tech is either an asshole or a fucking moron.
Neve, don't take this the wrong way, but Muttley's right.
Aside from the fact that adjusting the truss rod doesn't "raise or lower the strings," we simply don't know enough to answer the OPs problem.
What frets are buzzing? Is it just open strings or just fretted notes? If the former, the problem is most likely the nut, not the bridge or amount of relief in the net. Is it just a couple frets in one area of the neck? Only above a certain point or below a certain point? Does every single fret buzz, including open strings? Et al.
It's the kind of thing I could probably sit down with and diagnose in five minutes if I had the guitar in front of me (and I'm not nearly as knowledgeable as Mutt), and potentially fix in about as much time again as well, but there'd be a LOT of things I'd have to check before I could say with any degree of confidence that his problem was a nut that was cut too low, or not enough/too much neck relief, or a high 8th fret, or the bridge or an individual saddle being too low, or even just simply a kind of funky string. Whatever. Point is, while raising the saddle MIGHT fix his problem, it also might not and playability might suffer for it, for no actual benefit.
EDIT -
Wow, just saw this. I think I can diagnose your problem - your tech is either an asshole or a fucking moron.
O the bright side, you probably have a much nicer Strat for it today. Which I guess is nice...
