M
Minion
Blow Me !!!
Make sure that you are plugging all of your audio equipment into the same electrical circuit/outlet ......
I recently moved into a new jam space , and we had the PA plugged into an outlet at one end of the room and we had the guitarists/singers mesa dual rec plugged into an outlet at the other end of the room , Now everytime the singer/guitarist got close to the mic he would get a major shock .....
To solve this we plugged everything into the same outlet .....
I believe the probelm lies with different ground potentials with different outlets , if the ground potential is different then the differance in voltage between the two outlets will give you a shock ......
Cheers
Cheers
