jmxdrummer
Love to get your feedback on this new song I completed today. The song is entitled "Shoot the Sky (unmastered)"
Thanks
http://www.soundclick.com/snapmare
Thanks
Your kick and snare sound kinda muddy and the crashes and hats sound really phasy and possibly a little loud.
Guits and bass sound o.k.
Is there a reason why the drums sound like they come in late? Like why do the guitars kick in andthe kit comes in like shortly after them?
Thanks for the feedback on the drums. Will go back and clean up the kick and snare. I will also look into lowering the cymbals in the mix. thanks again.Agree with the previous comment about kick and snare... The cymbals have a fade in? this could be a compressor issue. I have the Waves SSL and has the fade in option, ones i selected for error. So, if that's the problem, is easy to solve, if not... mmm, don't know what could be.
Ok then the problem might be the settings for the compressor... you should use a fast attack and a low release, the rate depends on you, i try to keep it low (3:1) to avoid boosting the other drum pads. Also a filter is recommended, kill the frequencies under 500 - 800 hz, if you want of course, sometimes they are cool, sometimes they aren't. That should do the trick.
