Luca Brasi
Hi,
I use my Digitech GNX3 for recording and I'm having an issue with a guitar noise that might be grounding related.
When I plug my electric guitar into my GNX3 I get a loud hum that is only relieved by putting my hand firmly in contact with the strings or bridge. In most cases this is fine, but when I remove my fingers from the strings or my hand from the bridge, the noise is there and it ruins the take. I am running my guitar directly into the GNX3 and the GNX3 directly into my computer using a mono (two 1/4" male ends) to stereo 1/8" Y cord.
I've checked the guitar's electronics, all the grounding connections are good (the bridge and pickups are all grounded). This guitar does not have a hum when plugged into my amplifier, only when it's plugged into the GNX3. I also have a second electric guitar that does not have a hum problem when plugged into the GNX3. In all instances mentioned I used the same cable from the guitar to the device.
I've taken the GNX3 plug out of the outlet strip and inverted its position and replugged it with no difference in the noise. I'm wondering if anybody on this forum might have an idea as to what my problem could be. I wondering if it has anything to do with the Bumblebee caps that I installed in the guitar (but they work fine with my amp-no noise), however, my other guitar has the same cap in it and has no noise issues.
I am wondering if I have some sort of loop effect going on.
Thanks in advance!
Steve
Thanks in advance!
Steve
