ralpheo
Stuck in Neutral
Ok modders,
I need some help with a Digitech PDS1002 I bought 2 weeks ago on ebay. I had one of these from about '86 until I sold it in 1999. Stupid move!
I tested it out and found that when I have both the effect out and the dry out connected to the inputs on amps or any other such device, I get absolutely no sound. If I use a use a means to split the signal (in this case a Zoom 504 acoustic fx pedal) before the input of the PDS1002, I get a normal output.
At this point I would actually be ok with that solution, except that I have now found that I have about 5 minutes of use before the signal starts to decay and disappear. I thought at first that my battery might be dying, but that's not the case. (The led never goes dim, I used the battery for quite awhile in my tube screamer, and tried a second and third battery in the delay pedal.)
If I disconnect and leave the unit off for a few hours or days, it's ok, but again only for a few minutes and then it's useless.
I'm wondering if:
1) a capacitor could be worn out, heating up and discharging at too high a rate and if so which one do I replace?
2) one of the delays is worn out and again, which one?
3) something else entirely?
I would appreciate anyone's help on this. I'm not afraid of digging into this thing, but at the same time I don't want to wind up with a box of $80 worth of useless circuits.
I'm going to include a stock photo of the guts, but I haven't located a schematic yet.
Thanks guys.
I'm wondering if:
Thanks guys.
