F
fluffy13
Which do you guys usually use to mix down? I usually go for speakers, but I get quite annoyed when it all sounds very cluttered on the headphones. Is there an industry standard for that per say?
fluffy13 said:Which do you guys usually use to mix down? I usually go for speakers, but I get quite annoyed when it all sounds very cluttered on the headphones. Is there an industry standard for that per say?
Avoid mixing on headphones if at all possible.
), didn't they sometimes mix on headphones ?
, I genuinely don't understand this and I want to. Having said that, I'm only just now beginning to understand compression. The time will one day be here when I can laugh at my present folly.. What I don't understand at this moment in time is that if stereo speakers are 'enhanced' to make them sound 'good' in the high and low end and everyone is ultimately going to listen to their music on such, how is a flat response monitor going to be better ? I was listening to some stuff I knew well on my friend's monitors the other week and I had to strain to hear the bass. I'm not up for an argument by the way, I genuinely don't understand this and I want to.
I think G-Jay gave an excellent answer to this question. To over-simplify it, in a perfect world, one would not mix on headphones because they introduce their own problems. At the same time, in a perfect world one would not mix on cheap loudspeakers and/or in a bad-sounding room either, because they introduce their own set of problems.In "the old days"D
Now, I wouldn't do a mix on headphones unless maybe it was a very sparsely instrumentated song and even then, I'd be constantly checking to see how it sounded via the monitors which would beg the question as to why I was doing it on phones in the first place.
With great cans, a crossfeed plug in and LOTS of listening time and mixing experience on your headphone setup great mixes can be done.
But why go to all this trouble when decent monitors will always work 10 times better?
In most cases there is little to no difference between a "hi fi" speaker and a monitor speaker. They're all just trying to reproduce sound accurately with varying degrees of success.But Terra's point about his monitors not reproducing the amount of bass that's there in reality is one that's confused me for a long while. What I don't understand at this moment in time is that if stereo speakers are 'enhanced' to make them sound 'good' in the high and low end and everyone is ultimately going to listen to their music on such, how is a flat response monitor going to be better ?
. They can be useful when you're looking for left-to-right balance in your mix. I can't think of anything else right now. I personally wouldn't spend much time using them to mix. I'd just pop them on every once in a while for the two purposes I stated.PS
You can get some decent used monitors for $400!
I just saw two listings on eBay for Mackie HR824 monitors for under $400.![]()
...but I just don't see that money should be the main deciding factor for that question...if you get my meaning.Well...OK...let's be realistic.
I think you will agree that $400 ain't enough for much of anything when just starting out. Thing is...everyone wants to buy EVERYTHING for their budget, no matter if it's a $400, $4000 or $40,000 budget!
Let's talk about room treatment.
I don't want to suggest that going without room treatment is better...however, I see way too many guys get very caught up with that as though it's a magic element AFA having a studio that rocks VS sucks.
Quite frankly...most of the rooms people use for home studios need a LOT more than some bass traps and foam...which is what a lot of folks blow their precious, limited budgets on. Some of them get WAY too scientific about it...others just put up foam/traps wherever there is an empty wall.
Often it's a total crapshoot no matter how much "treatment" they put up....and man, I've seen some downright UGLY studio setups on these forums, mainly due to the "treatment", which sometimes costs them a LOT!
Then they go out and buy $59 condensers and $99 preamps to go with their fancy treatment.
Point I'm getting at...there's been a lot of great sounding music recorded in NON-treated rooms, like a typical home living room...and there's been crappy sounding music recorded in studios that were almost over-treated.
So it's hard to say what's the best thing to spend $400 on.
It's like the reoccurring question that comes up on forums when budgets are small...
"What should I buy first, a great mic or a great mic preamp?"
I say...it doesn't really matter all that much, as eventually you will need both!
None of that really clarifies the headphone VS monitors question any better than we've already tried to do......but I just don't see that money should be the main deciding factor for that question...if you get my meaning.
Sometimes it IS smarter to buy for the long-term rather than just to fulfill an immediate need that you then have to fix later on anyway.
So yeah...I would still spend the entire $400 on decent used monitors..and the treatment can come later when there’s more clams.
I just think that is better than spending $400 on several crappy items just so you get more quantity out of your $400.
Don't you agree?
Anyway...in case anyone wants to go the headphone way...I suggest you check out the Fostex T50RP semi-open headphones. They are absolutely fantastic for critical listening. They have a huge bandwidth and flat response and are very accurate, and they can be found as cheap as $60 on eBay (new)...though they sell normally for $75-$100.
I have three pairs...along with a bunch of Koss Pro4AA that I use mainly for tracking as they offer super isolation...but the Fostex would be the better choice for mixing, if anyone is going that route instead of monitors.
The original problem he raised was when he mixes with speakers it sounds cluttered on headphones. G-Jay has it right I believe in that it may be money better spent on headphones than to treat his room and end up fruitless.But let's get back to the OP's question.
He asked what was the industry standard for mixing...and the answer to that is monitors, not headphones....though you can find specialized/unusual situations where a pair of headphones can come in handy.
