squibble94
Nature of Force
Hey Guys
I assume many of you have the same problem as I do. LACK OF MONEY!
I have a solution to making bass sound good in a mix without using an Amp or a DI Box. I've heard great mixes, but the bass sounds like it was plugged into a mixer/interface and left alone after it was recorded. This process is completely free if you have a DAW.
Step 1: Download this VST (FreeAmp3 Full) and put it into your DAW. http://frettedsynth.home.att.net/
Step 2: Plug bass into your mixer/interface and record your part.
Step 3: Apply the FA3_Full plug in to your bass track.
Step 4: Mess with the settings. This usually sounds okay. The settings in the picture fit my bass well for most of my mixes.
Step 5: In your FX Bin after FA3_Full, apply an equalizer plugin. EQ to taste (generally you want to take out the high frequencies)
Step 6: After the EQ in you FX Bin, add a Compressor. Use whatever settings you like. I use Boost 11.
NOTES: This may not sound right with every bass pickup! Bass should be somewhat quiet in the mix. If you listen to professional mixes, the very low frequencies of the actual song are taken out.
Keep in mind, these are only tips.
I have a solution to making bass sound good in a mix without using an Amp or a DI Box. I've heard great mixes, but the bass sounds like it was plugged into a mixer/interface and left alone after it was recorded. This process is completely free if you have a DAW.Step 1: Download this VST (FreeAmp3 Full) and put it into your DAW. http://frettedsynth.home.att.net/
Thanks a lot! I know this won't work with every bass. But I've tried it with several basses and it sounded pretty decent.
