Bristol P ==
Thanks very much. I
did find the file by following the path you provided. For other readers, that path is as follows:
C:\Documents and Settings\
User (per your system)\Local Settings\Application Data\Sony\ACID Pro\7.0\
acidpro.plugincache.xml
I'm pretty well versed in Windows XP but something has occured that I've never seen happen before:
Windows Search will
not find the file if I search from the
Local Settings level of the path, or any level higher in the path.
C:\Documents and Settings\User\Local Settings\Application Data\Sony\ACID Pro\7.0\acidpro.plugincache.xml
Windows Search
will find the file if I search from the
Application Data level or any lower/deeper level in the path.
VERY STRANGE. I can't imagine why Windows Search cannot find the file until I drill down to at least the Local Settings subfolder - and search that directory and its subdirectories...
In any case, I drillled all the way down per your excellent instructions. The file was exactly where you said it would be. I would NEVER have found this otherwise.
I've made note of the file name and location, and your advice on the subject. Will delete the file and rebuild the plugins directory tomorrow, and will report the results for the record.
Thanks very much, Bristol Posse.
