N
noiseordinance
Hi there. So this may be a question with no solution so long as I'm recording in my bedroom. I'm recording vocals and pick up a decent amount of background noise (surprise surprise). My computer is in the same room, and I imagine the fans are a decent portion of the noise. When I delete the light hiss between vocal parts, it becomes fairly audible when the silence ends and there is an abrupt hiss of background noise right before the next vocal part. I have attempted to capture a noise reduction profile and run the noise reduction on my vocal samples but that sounds like crap.
Obviously, the answer would be to isolate vocal recording as much as possible, but in an apartment, there's only so much you can do. Just curious if there's any tricks that people use to minimize hiss between vocal parts without making it obvious. I'm thinking for now, the best I can do is run vocals through compression > parametric EQ (something to rid the high-highs and low-lows) > delay and between vocal parts, phase in and out of volume levels so that it's not as apparent?
. If a small vocal booth is not able, try shutting of all electronics that you can (aside from your computer of course), and move your mic to the other side of the room. Acoustic treatment is a must if you want quality recordings... So I've been told...
I did, however, place some clothing between the computer and the mic which seems to have helped a lot. I kinda like the suggestion about putting the mic in my closet with clothing, and I might have to try that. I just wasn't sure it there's any post-recording tricks that people do to smoothly remove background noise. I know that you can't polish a turd (too much anyways; in the recording world, there are ways to slightly shine turds... see "autotune"). Anyways, thank you guys for all the suggestions. Very helpful... this forum is great.
