K
KrispyDK
Hello,
I want to record my active bass into Cubase on my PC using the technique of DI'ing the bass on one track and having the amp mic'ed into another track and then blending the 2.
Someone on here has suggested using a 2 channel preamp and a Y guitar cable splitter with one jack on one end and two at the other. Then one cable goes from bass into the amp and the other goes bass into the preamp (DI). The mic on the amp will then go into the other channel on the preamp. Then the preamp can send the 2 channels into my PC.
Sounds reasonable to me. I'm not sure about the Y guitar cable splitter though. The only ones I've found have been one stereo jack at one end and 2 mono at the other. Is this the right one to use for this purpose or should it be mono jacks at both ends?
Also, do you think this is the right route to take? Will i lose much signal quality by using a split cable? Should I use a DI box between my bass and the amp/preamp or will I lose more signal quality by adding the DI box? Then, should I use an active or passive DI box with my active bass?!?!?!
Please help!!
Please help!!
