bozmillar
I just read your article on tracking levels, and it makes sense. Here's the link for anyone else to read. http://www.massivemastering.com/blog/index_files/Proper_Audio_Recording_Levels.php
But, I have a couple questions. This is all speculation because I haven't tried it yet, but i feel like there are some exceptions to that, especially for home recording guys. I'm going to go out on a limb and speculate that that only really applies to "vintage" type gear and other outboard preamps. I mean, lets take a look at what most people recording at home are using: audio interfaces with a built in preamp.
The preamp is built in to the device and is connected directly to the A/D converter. Whoever designs the interface gets to choose what voltage level maps to 0dBFS. Whether 0dBFS is 0.5 V or if it's 20V, the user doesn't know because there's no direct output from the preamp. Since the preamp doesn't have to play nicely with anything but the A/D converter. Neither the preamp nor the A/D converter have to be designed to work optimally at +4dBu.
Since people are generally under the assumption that hotter without clipping is better, it doesn't seem unlikely to me that the designers of the interfaces most people use would make their product to in fact sound better at higher levels since this is how people are actually using them.
Any thoughts?
Any thoughts?
. But on the digital side, in these days of 24-bit recording being able to handle what is probably at very best 70dB of analog range between noise floor and peak, there is not only no harm in lower conversion levels like that, but on the digital side is most likely preferable because it gives one just that much larger of a digital palate to work with once they do get to to the digital domain.
