Hi everybody.New to this fourm.Just getting into some home recording.I recently purchased the apex usb condenser mic for recording some vocals and acoustic guitar.Now what i noticed is that when i sing into the mic it sounds wonderfull coming through my computer speakers,but i tried recording a song using the audacity program and i put it on a cd and it came out flat.sounds awfull.Anybody know why this may be?I'm only using the realtek onboard sound on my computer.Is this the problem??Any help greatly appreciated.Thanks
First off it will help you to know what an A/D converter is. An A/D converter is an Analog to Digital converter. what this does is it converts analog audio (voice, guitars, drums) into digital audio (ones and zeros) so that your computer will be able to store the audio. The importance of an A/D converter is it decides the quality of your digital recording along with bit depth and sample rate (but I'll save explaining those for another time).
The A/D converters in realtek/soundblaster/integrated type sound card aren't exactly the best. They will be ok for beginners but you might want to upgrade to something a little better later on.
Ok, here we go, Your condenser mic is an interface and a phantom power supply all on it's own and while usb mics aren't the best out there they will do the job just fine for you. So the problem wouldn't be with the A/D converters on incoming audio.
Once the audio is stored on your computer (in what I'm guessing is 16 bit, 44.1KHz) it should sound the exact same as if you were just monitoring the incoming audio from your mic.
The next thing we are going to need to know is does it sound dead and lifeless while being played back on the computer or only on the CD?
If it only sounds lifeless on the CD try checking what quality your burning CD's on.
Also, Here is a free DAW (Digital Audio Workstation) that is much much better than audacity. It's called Reaper and it's a free unlimited trial with the only downside being (Now don't quote me on this as I'm not 110% sure) that it takes a bit longer to load up unless you pay the 60$.
