adamvelvetu
i am working on recording a friend's band...we've finished tracking and i'm starting on the mixes. any advice on this rough version would be greatly appreciated:
hello-
would certainly appreciate some more feedback...i think i like how the guitar/bass are eq'd and sitting together and their panning as well...the drums seem to be working too? would appreciate any input on getting the vocals to sit a little bit better...i feel like they could come down in volume.
thanks again!
http://www.lightningmp3.com/live/file.php?id=21573
That's a bit better, but now I think the bass is a bit too high.
My main issues with the mix are still the transition out of the intro and the drums.
Did you track the intro guitars and the rest of the guitars in separate takes, or did you do them all in one take and manually split them so that you could apply different treatments to them? If I was working on this recording, I think I'd have the left-biased intro guitar run through the full song, and have a second slightly right-biased guitar (double-tracked) kick in at the transition out of the intro. This way, I think you'd get a similar effect but with better continuity. I'm not saying this approach is the ultimate answer, I'm just relating what popped into my head when I listened to this song.
As for the drums, I still think they need to be more prominent. I'm not sure if you're running hard compression on them or something which is causing them to lose their pop, but they're just not cutting through enough. How did you record them? I'm guessing you didn't close-mic anything, from the sound of it.
Matt
Matt has been on the money the whole thread. These are some truly speaker-damaging levels of lofi distortion. I can't say I'm a fan of the sound choice at all, but then, I don't understand the genre, it might be necessary. It's very juxtaposed against the clean and upfront vocal. The bass level is much better than the first pass, but it lacks definition and clarity. The drums still could kick harder. Interesting listening to this evolve!![]()
i went back and did less work to the guitars...when i first heard them i felt like they sounded bad and i eq'd them but your comment got me thinking so i moved them back.Did you track the intro guitars and the rest of the guitars in separate takes, or did you do them all in one take and manually split them so that you could apply different treatments to them?
first, thanks again man! yup, the intro guitars were tracked as separate takes. what i did on this little version is drop out the guitar that is playing that main hook, which i like the sound of...makes for a bit more interesting song.
http://www.lightningmp3.com/live/file.php?id=21583
i used 3 mics on the drums and got 'em pretty darn close (bass drum in the hole, etc...). i had ran the snare and bass through a compressor--i ran two versions one with and without the compression.
So you ran the snare and kick mics through a hardware compressor when tracking?
Are they both the same exact take, but with a different signal path? If so, and if re-tracking is not an option, I'd suggest maybe importing both versions into your project and blending them.
Then, maybe do a complete re-mix, setting all levels against the drums.
Thanks again for all the help...much appreciated and I'm having a lot of fun![]()
No problem. To be clear, I'm pretty new to all this myself, but through hours and hours of recording and mixing over the past year--and, obviously, learning from this here forum--I've had many, many "Aaahhh, now I see how that works" moments. I think one of the reasons I've paid such close attention to this particular thread is that some of my biggest "moments of enlightenment" came out of trying to address things in my work that are eerily similar to what I hear in your recording. So, since these experiences are very fresh in my mind, I figured it'd be good to share them.
Yeah man, this has been a great forum to be participating in. With that first mix I had reached the point where my ears just weren't cutting it...your perspective has really made it better. I wound up merging those two bass drum sounds and really liked the overall effect. I made a judgment call and dropped that intro guitar altogether...instead going with a more effects driven thing. I set the drums so they hit at about 9db and then the bass and guitar so they hit about 12db. I think this freed up a lot of space. I wound up moving that lead guitar part to the center channel as well.
http://www.lightningmp3.com/live/file.php?id=21600
I just got Soundforge 10 and a few other plug-ins that work well with it so I decided to put through a bit of mastering as well...slight stereo imaging (below 347hz and 2ms delay on those freq. above), eq, and some slight limiting...hopefully there's a difference in clarity that ya'll might want to comment about
http://www.lightningmp3.com/live/file.php?id=21602
hope the weekend is swell!
I like that intro much better, actually. Good choice. Sounds a lot more fluid.
These two mixes are definitely the best yet. Not sure which one I like better. The second one kind of jumps out more, but I'm wondering if that's only because it's a bit louder. I'd say, just go with the one you like better.
Still not crazy about the sound of the kick, but at least I can hear it now.
Have a good weekend
Matt
