Kingofpain678
Returned from the dead
As important in a clean guitar tone as they are in dirty/distorted guitar tones?
The only people I've seen who prefer solid state cleans are a few jazz guitarists and metalheads. Tubes will always be > solid state as well as digital.
In ANY tube amp, the tubes, in conjunction with the transformers, the circuitry, and even the location of the tubes in association with the transformers have EVERYTHING to do with the tone.
If you have an amp with controls that include a preamp volume control as well as tone controls and a master, then the settings you use (gain staging) will determine how much of the preamp tubes or the power amp tubes will affect the final output of the amp to the speakers. Each set of tubes does something different to the sound and only by experimenting with your guitar and your style are you going to determine what you'll get .
Clean tones are for the gays. Turn it up.
They are discussing Vacuum Tubes, not drumsticks!
VP
No shit, and I'm still better qualified than you are!
VP is a hack and a fraud that doesn't know anything about guitars.
Cleans up electron flow, n00b.
When solid state overdrives they tend to produce odd harmonics that seem harsh. A MOSFET solid state amp sounds similiar to a tube amp. I think they have output transformers in them which could explain the similiarity.
VP
You really have no clue, do you? What kind of harmonics do saturating transformers produce?
