Compression? Expansion
  • Thread starter Thread starter BDiNkY30
BDiNkY30
BDiNkY30
I am fairly familiar with compression and how to use it, but i would appreciate it if someone would elaborate in detail why it is used and maybe throw in some tips. Also i have not the slightest clue how to use expansion nor do i know what it does. Please explain in moderate detail so that i may get a better understanding. Be gentle =]
from an earlier post
Understanding Compressors and Compression
from an article by Barry Rudolph
A compressor consists of four basic parameters:
Ratio
Ratio is a way to express the degree to which the compressor is reducing dynamic range. Ratio indicates the difference between the signal increase coming into the compressor and the increase at the output level. A ratio of 10:1 would mean that it would take an increase of 10 dB coming into the compressor to cause the output to only increase 1 dB. Ratio is a constant value, as it doesn't matter how much compression is taking place; the ratio of the input change to output change is always the same. Compressors and limiters are really separated only by a loose definition: Generally, compressors have compression ratios up to 8:1, while limiters have ratios higher than 8:1. Most professional compressors have either fixed selectable ratios (such as UREI's 1176 with presets of 4:1, 8:1, 12:1 and 20:1) or continuous variable
ratios (such as the dbx line of professional compressors).
Some recent compressor designs instantaneously change ratio depending on the program's dynamic content and the constraints of the front panel control
settings.
Threshold
Threshold is the level of the incoming signal at which the compressor amplifier changes from a unity gain amplifier (like a straight piece of wire, theoretically) into a compressor reducing gain. The compressor has no effect on the signal below the threshold level setting. Once threshold is reached, the compressor starts reducing gain according to the amount the signal exceeds threshold and according to the ratio control setting. Threshold level could be thought of as the "sensitivity" of the compressor and is expressed as a specific level in dB. The exact moment the compressor starts gain reduction is called the "knee."
"Hard knee" compression describes this moment as sudden and certain. "Soft knee" or smooth knee compression is a less obtrusive change from simple
amplifier to compressor. Soft knee widens or broadens the range of threshold values necessary for the onset of compression. On quality compressors you can switch between hard and soft knee compression. The amount of gain reduction is measured and read on a standard VU meter whose needle rests on the 0 VU mark. The needle will deflect negatively downward to indicate how much gain reduction is occurring in dB. VU meters are RMS or average level responding and do not indicate fast or peak gain changes. LEDs are also used for VU meters, and they will better indicate peak levels. A well-designed
compressor will have a good meter that reads input level, output level, gain reduction and any excessive peak output with an LED clip indicator. Once the amount of gain reduction is determined, the recording or operating
level is readjusted with the output or make-up gain control on the compressor.
Attack
Attack time refers to the time it takes the compressor to start compressing after threshold has been reached. Typical attack times range from less than
1 millisecond at the fastest to more than 100 milliseconds at the slowest. Attack time settings affect the sound quality in terms of overall perceived brightness or high-frequency content. If you use very fast attack time settings, the compressor will activate very quickly, reducing gain instantly at the waveform level of the sound. Since transient information at the front or attack portion conveys brightness character, especially with percussive sounds, immediately reducing it with the compressor will dull the sound. Selecting a slower attack time will allow the transient portion of the sound to pass through before the compressor starts clamping. However, if the attack time is too slow, ineffective and tardy compressor action may result.
If you compress a snare drum track with a fast attack, you may notice a diminished or shortened attack of the front portion of the snare drum sound. Instead of a good "hit" at the beginning, you will hear a very short "blip." If
the attack time were even faster, you wouldn't hear any snare attack at all. Adjusting the attack control to a slightly slower attack time will lengthen this blip back to the original snare attack length. Engineers use a compressor to get more attack out of a snare drum by using a low threshold and a high ratio. After making up gain with the output level control of the compressor, the attack portion ends up greatly amplified just before the compressor starts squashing the trailing portion of the snare drum sound. I like to mix this "twacked" sound with the original un-processed snare drum track.
Release
Release time is the time the compressor uses to return to unity gain after the input signal has fallen below threshold. The compressor is said to "release" from gain reduction. Typical release times on popular compressors go from as fast as 20 milliseconds to over 5 seconds. Most engineers envision their compressors doing their job of gain reduction quickly
and then releasing quickly to get out of the way. For the most part this holds up for pop recordings, but super fast release times, along with a fast attack time setting, will distort low-frequency sounds, as the compressor is capable of gain change within the period of the sound's waveform. You can demonstrate this by using a very fast release on a bass guitar compressor and have the player play loud and sustained notes. Over-long release time settings are another form of distortion, since gain reduction is "stuck" clamping the sound down for an unnaturally long time. "Pumping" and "breathing" are engineer jargon words for obvious compressor artifacts or side effects with maximum compression. Sudden and usually unwanted
deep gain reduction is called pumping, while a slower return (release) to operating level with a noticeable rise of the noise floor is called breathing. Newer compressor designs have clever predictive and adaptive schemes that reduce these side effects, making the compressor's action nearly undetectable or at least tolerable in most intense gain reduction situations.
Using Compressors in music
Trying to arrive at proper recording level can be like chasing a moving target, especially if you are working with inexperienced musicians or singers. It is easy to just "pack" the signal from a widely dynamic singer into a compressor, crank it way up and call it a day! On the other hand, the creative and caring engineer may use an equalizer in the sidechain of a compressor to selectively compress certain problem frequencies of the singer's voice. The sidechain input is a direct path to the compressor's detector circuitry, where an external signal can also trigger compressor action. Using an equalizer in the sidechain makes the compressor more (or less) sensitive to sounds within the EQ's frequency passband. Other sidechain compressor applications are de-essing and ducking. De-essing is accomplished by connecting an equalizer to the sidechain of a peak limiter and boosting, with a medium to high Q, the "s" frequencies anywhere from 1.5 to 6 kHz (depending on the singer). Strong "s" sounds are quickly reduced
without (one hopes) too much consequence to the rest of the vocal sound's signal. Ducking is gain reduction that is triggered from a different audio source altogether. The most common usage is to "duck" or lower a music bed (track) whenever a narrative voice-over is active.
Bass guitar
Generally, bass guitars seem to sound better when using some compression. I sometimes rely on the compressor to pull up some additional bottom end and warmth. I like to use a leveling amplifier for bass guitar such as an LA-2, Anthony DeMaria Labs or a Tube-Tech CL-1B compressor set up as a leveling amp. Based on the song's tempo and/or the bass player's style of playing, I might start with ratios of 5:1 with a medium threshold setting, medium attack and a slower release time. Unless you are looking for a pumpy effect or have a very wild bass player that the producer would like to squash, I rarely compress bass guitar more than about 5 dB max VU.
Vocals
A lot of anguish and pain surround the recording of vocals. Maybe some singer
insecurities, producer apprehensions and overall great expectations weigh on the arrival of a stellar vocal sound. It's about preferences, and vocal sound is subjective and contextual within the backing track. It does not exist on its own unless you are recording an a cappella performance. What I might think is a great vocal recording on a certain CD may be not be what the singer and producer are looking for to convey the emotional import of the artist, the song's lyric or the vibe of the song. At the first vocal recording session, you will want a starting point vocal sound that fits the singer, the song and the production. This starting point sound will work well to capture the immediacy of the moment and hold up later in mixdown. After mic selection, mic preamp selection and EQ setting, a compressor type is decided. Although there is much interaction between all these components, my starting point settings are predicated upon a +4dB level coming from this mic/preamp/EQ chain. For vocals, I tend to use compressors with adjustable attack and release time controls. I like tube-based compressors, although for more difficult control problems I would go to a VCA-based unit. If you were to set the threshold at
about 0 dB, the ratio at 4:1, the attack and release at middle positions and adjust the output level for a good recording level, you'd have about 3 to 6 dB of compression and probably make most people happy. This is just a good starting point, and you should get in there and change those settings to your own taste.
Stereo mix compression
A popular place to apply compression is on the entire stereo mix as it is going to the master tape. Stereo compression is also applied "after the fact," such as in mastering, but there is a big difference. If you are mixing your record into a compressor ahead of the master tape recorder (or DAW or whatever), then you are mixing many sources (tracks or elements), each with its individual dynamic content. Making mix moves (especially big gain
changes) directly affects the compressor's action, which, of course, affects the relationship of all the other mix elements, that is, the whole mix! If you do not use a stereo compressor at mix and compress at mastering, then you have just the dynamics of a 2-channel stereo mix for the compressor to react to. Many engineers and producers mix into a compressor and then have
the mastering engineer compress again, while others prefer to wait until mastering to compress digitally. A good starting place for the stereo mix compressor is a lower ratio with medium attack and release time settings. Set the threshold (and output level) so that you can hear an increase in level (average loudness) when you A/B the compressor in and out of circuit.
Remember, this is just a starting point! You may want to use a higher ratio to control peaks better and/or a lower threshold for more compression and denser overall finished sound.
a good book is guerilla home recording...I think there's a copy for sale in the for sale forum...excellent for everything
Less detail - But the core of the question --
Compression makes LOUD things QUIETER.
Expansion makes QUIET things quieter.
It is used for the same reason eq or reverb or any other effect is used: Something about the recording doesn't sound right and the guy calling the shots thinks compression can fix it.
This isn't going to make much sense until you really wrap your ears around the ins and outs of your compressor, but you use it when things sound too "open". To describe it in the visual way my ears work (I "see" sound so it's always easier to describe it that way), a sound that needs a compressor "looks" like light fluffy chocolate mousse sitting in a part of the song that clearly needs heavy pudding instead. The compressor turns fluffy mousse into dense pudding.
The only way to use a compressor is to know how it reacts to input. Doesn't matter if you know what ratio and attack DO if you don't know how they ACT. Compressors are usually subtle beasts, especially if done right. That's no good for learning. Crank every compressor knob to it's max, then down to it's min. It will be tasteless. It will probably be wrong. But it will also be the only shot you have a getting a handle on the sonic characteristics. Once you know what to listen for, you can then venture into "subtle" and apply everything correctly. Expect this to take a few months. Compressors don't come easy.
One of my favorite "tricks" is to find the attack time that exactly lets the transient attack through. Once you know that time, you have more control. If you want more "dull" you set your attack faster than that time. If you want more "pop" you set your attack longer than that time.
To find that time, set the threshold and ratio where you want them. That's a whole kettle of fish in itself... But anyway, set your release time to zero. Now set your attack to zero. Hear how dull it is? It is most likely distorting, too. Now crank your attack all the way up. It is bright again. Find the exact point on the attack knob where if you make it any shorter at all, the sound starts to get dull. That is the point where your transient is just making it thought.
After you have that, make a final attack and release decision. You will notice that as you raise the release up from zero, the sound of the compressor becomes more noticeable. It takes experience to know when the music wants a noticeable compressor. Also be aware that bass sounds do strange things with slow/zero release settings due to the slow movement of the bass waves themselves.
Expanders are better known as "gates" (if I'm simplifying...and I am). Say you have a channel with background sounds... Like a snare mic that also hears every other drum. An expander can keep the rest of the kit quiet (or dead-silent) while keeping the snare hit at full volume. Of course, you have to know if the background noise on a track actually should be removed in the first place. You'd be surprised how often it shouldn't.
That's only half of it. Compression makes loud things quieter AND quiet things louder. It narrows the dynamic range of the signal.
Expansion does the opposite...it widens the dynamic range. It is used to make undesirable low-level signals (like noise) even quieter while allowing louder signals (like whatever you're recording) louder.
Well, not really. Standard downwards compression does only act on anything over the threshold. It doesn't "do anything" to the quieter parts of the signal. The quiet things only become "louder" because the louder things that made them appear quiet in contrast are themselves quieter. If you apply makeup gain so that the pre and post compressor signals peak at the same levels then yes, the quieter parts will be louder, but that doesn't mean the compression has acted on these parts. Its all relative.
this is a good thread. it needs to be stickyed somewheres.
becasue im really dumb.
