L
littlebunny
I'm a new owner of a Rocktron Voodu Valve and a Behringer FCB1010 midi foot controller. I have it all hooked up, but can't figure out for the life of me how to get the foot controller to work like I want!
The controller is a nice, big one, 10 numbered pedals, plus an "up" and "down" as well as 2 expression pedals.
First, I've "reset the midi channel setting in the global setup" as directed in the manual. I'm assuming what this does it set everything back to a "factory reset", or undoes what the previous owner had it set up/programmed. I've reset this numerous times.
Now, what I want to initially do is just run up and down my Voodu Valve presets and have one expression pedal be a volume pedal, the other a wah pedal.
The problem I'm running into is total inconsistencies. I can run through, let's say bank 3, which will start at preset 30 and then when I go through the 10 numbered pedals, it changes the presets accordingly. So if I hit #7, the patch changes to 37, #3 the path changes to 33. Sounds logical, right?
Then I go up to another bank, let's just say it's bank 5, so it should be patch 50 and should work just like the previous paragraph (#7 pedal would give me preset 57, etc...) It sure don't, though. The # pedals appear to just pull up random presets, they're NOT sequential as you'd expect.
Any ideas what's going on?
