R
reelshows
Today i received the replacements for my start and run capacitors in my akai 1700. They are 1/2 the physical size as the originals. The originals were metal, the new ones are plastic. The sizes and volt ratings are the same, except one should be a .5uf and the replacement is a .68uf. The 2uf is so small that it won't fit in the bracket, but i can strap it with a nylon tie.
I believe they will work, just wanted some other opinions before i solder and can't return.
I just finished a unit on electricity in physics. Same formula except we used it to find Equivalent Resistance.
