D
dintymoore
Guest
Here's how I've been making unbalanced cables with Mogami 2792 three conductor cable:
1. strip the outer insulation, and pull the bare wire to one side and twist it
2. on this cable, you need to remove the black rubber on each of the two (clear and red) inner wires as, believe it or not, that rubber is conductive (!). I found that out the hard way... but I think that it's one of the reasons this cable is superior to some others.
3. strip the insulation off of the red wire.
4. the stripped red wire has "dental floss" in it to add strength but that makes it awkward to solder so I quickly pass a flame over it to burn it off.
5. twist the stripped red wire together with the twisted bare wire.
6. this is how one end is connected: the clear wire is the "hot" or tip and the combined red wire with the bare wire is the ground. There is no standard that I know of for this and using the red wire for the hot is fine too (even makes sense) and as long as you are consistent.
here's how the other end goes:
7. (crappy camera sorry) after I remove the outer insulation as in step 1. above, I use scissors to cut the bare wire off as close to where it comes out of the outer insulation as possible
8. this is what it looks like with the bare wire cut off.
9. using something not too sharp as to cut through the outer insulation, I stuff the bare wire back down inside the insulation a small amount until it isn't visible
After stripping the conductive black rubber off of the wires, I attach it like this, using the clear wire for the hot (or tip) and the red for the ground (kinda hard to see I know):
So the cable is grounded at each end, it's just that:
* the grounded shield is not attached at one end so it really helps prevent ground loop problems
* you have the bare wire ground, then the red wire as a ground, and then the red and clear wires have grounds around them (the black rubber that's conductive) and that's pressing against the bare wire, so in the end you have a lot of shielding protection compared to the normal 2 wire setup.
It's common practice, though it really doesn't matter, to use the end with the bare wire attached (the one in pic #6) plugged into the source, like into the guitar, and the other end into your amp.
