P
Pykon
Hi,
please, write here how you equalize recorded bass track to fit in the mix.
- do you apply low cut (say under 40 Hz) to protect low end of the mix? If so, what kind of filtering you use (shelving low or hipass) and how high are the frequency and Q values (+ gain if shelving low filtering used)?
- do you apply hi cut? If so, what kind of filtering you use (shelving high or lowpass) and how high are the frequency and Q values (+ gain if shelving high filtering used)?
- when boosting low frequencies do you accentuate individual strings and sounds with a narrow Q values or boost a certain range? If you choose the second option, you prefer a peak/dip eqing or low shelving filtering?
- on which frequency range you concentrate when boosting low end of the typical, simple bass line: approx. 40-70 or 80-150 Hz?
Please, write values of Q, ranges and kind of filtering you use and how they depend on the particular notes the bass plays.
best,
Mike
best,
Mike
) - I personally have a real fundamental problem with the idea of arbitrary "starting points", mostly for the reasons I gave in the last post here. Whether we're talking panning, EQ, compression, or any other type of signal processing, there already is an arbitrary starting point; it's called "bypass" or "neutral".
