D
drbluezz
Which do you prefer? Thanks.
Tom
Tom
Fishman, Schertler, Baggs etc.....
If you must something hyper cardioid to reject feedback or a 57
Seems you may see it the way I tend to lean; Live = primarily damage control.![]()
Depends on the situation really...but it pays to have a good pickup in your acoustic.
Maybe I should mention I will be using the mic for an acoustic guitar playing bluegrass music at about any venue
Tom
Looking for a mic to play live introduces an entirely new set of variables
not least of which is having $300+ gear go walk about (been known to happen)
of the two mics mentioned gut instinct is that SM81 is less amenable to average live venue
(if one is independently wealthy, or has strict security under control, is playing relatively quiet venue's with reasonable acoustics then we're back to original answer)
Stepping outside the bounds of original question I would tend to agree with spirit of other responses that for anything other then a concert setting where crowds expect to listen relatively quietly and where performers are not physically moving while playing significantly that neither mic is optimal
the mantra is that all this stuff, whether playing live or recording is a nested series. of compromises . . . subjective experience suggests that attempting to use either of the mics listed (and many similar ones) in the typical live venue would tend to force compromise that would obviate the strengths of the mic. That is probably possible to obtain the same or superior results with less effort, perhaps less expense from different choice for projecting guitar into the crowd
And your mic of choice would be????
Tom
