Where can i get a metronome thing...
  • Thread starter Thread starter ElegyOfficial
ElegyOfficial
ElegyOfficial
Hey!
I was wondering where i can get metronome so i can customize it, kinda like where i make it for one riff 120 bpm then when the next riff comes up it will automatically be 150bmp
I don't know of any hardware device that will do that, although it's not something I've actually ever looked for, but normally you can achieve what you want via a sequencing program, or your recordiing program or your hard disk recorder or whatever it is you're recording on.
On my machine (hard disk recorder) it's called a Tempo Map. Although I've never used it.
You could also use a drum machine (which is a sequencer of sorts). Or you could record a standard metronome at speed A for X bars then speed B for Y bars and splice them together...
Many options.
Hey!
Most recording programs will do that - I'm a Reaper user, and it's just a question of using the "Insert Tempo/Meter Change" command. Count out the number of bars you need at 120, then when you need to switch to 150, insert a change and change the temp up to 150.
Or are you just looking for something to practice with? My favorite software metronome is YMetronome - google it. It's not programmable in quite the same way, but you can set it to increase or decrease speed in given increments ev ery X number of seconds/minutes, which is pretty damned cool.
