C
cellomangler
I searched this and using inserts as direct outs has been addressed but I was wondering if there was a way to use the insert signal as sort of an extra aux send and letting the signal continue through the mixer... Also if this degrades the signal by pulling some "juice" off it. Basically I'm hunting down ways to create custom monitor mixes. I don't have enough sends to give every player their own feed from their input so they can boost themselves in their headphone mix independent of the general headphone mix. Another way I was considering is using one of these personal monitors that lets you tap a mic line before it goes to a mixer as well as blend a mix signal with it. But this "tapped" signal would be pre-effects. Hope that was clear enough.
