I
IHRec1ATL
I'm stuck right now being able to record with 1 channel i guess only? In mono? In Magix Studio 05/Audacity both, the bottom level audio is FLATLINE! The top only is picking up. And the output just doesn't sound right. I'ma include actual visuals in a minute with how its hooked up.
SMH @ MYSELF. A friend of mine came thru, wanted to record a song and this is the only proram i have to work with(Magix Music Studio Deluxe 2005! IT COULD BE a setting on the computer or recording software or with my driver on my audio card(M-Audio Delta 44? Perhaps a connection (input or output) with my M-Audio Audio Buddy preamp? Does the mic plug straight into the preamp THEN OUT to the 44's BREAKOUT BOX 1 or 4 inputs and BACK OUT to whatever your speaker/output is playing to hear overall audio? Or does it go to the breakout box THEN the preamp?
I've checked the settings on the input/record section. I may have a selection incorrect(Delta 44 1/2 + Delta 44 3/4 + Delta 44 Multi etc).
Please help if you can. I'm currently about to try to uninstall the 44, start there. Reinstall with the newest driver from the site. I can't locate the actual disc from buying the audio card directly. I'd really prefer that one if i could find the disc. =(
I will be posting this to the M-Audio/Magix and other forums to help on the audio card/recording software side, but no help has come yet. Thanks in advance guys!
^^^ Real talk.^^^^ I'm bout to step out the door and meet Mr. Swisher
just 2 relax off this. I'm at a loss at to whats going on.
These are images plus text included on how i have them hooked up. Hopefully this gives you an idea visually. Yall help me out. I know its late in the evening, but, maybe someone can look out for me, help me figure this out.
Ima try to screen shot the settings to further help someone see if my settings to record are wrong which is why I'm only getting 1 channel.
Screenshots coming on :
1) settings in my recording programs(Magix and/or Audacity) record screen / options & settings screens
2) XP Control Panel>Sounds>Settings>M-Audio Delta 44
If you need me to post up a pic of another area screenshot-wise or anything to help squash this, let me know. I've got all the posts open, sitting in front of the pc.
Thank you so much for your time and I sincerely appreciate your time looking thru and potentially helping me.
[/quote]
***EDIT / UPDATED W/PHOTOS&SCREENSHOTS***
Well, I uninstalled a 1394 pci card out of the other slot, took the 44 out and slapped into the 2nd and last pci slot where the 1394 was. Looked in the Device Mgr under sound cards, no 44 was there. Just the icon in the control panel that never seems to go away after you uninstall it.
Cable 3 from the ALL CORDS SHOWN photo in post above is going from the mic, to the mic's phantom power box. Cable 2 is a MONSTER CABLE FEMALE XLR plugging out as MIC OUT from the phantom power box as w/an XLR MALE on the other end plugging into the M-Audio Buddy rear panel into the Ch1 of "MIC IN". To route the mic from there, it has the 1/4" jack MALE plugging out from Ch1 output(balanced/unbalanced) of the Audio Buddy to A 1/4" MALE into 1st channel of inputs on the Delta 44 breakout box. Routed out of ch1 on OUTPUT on B/O Box TO the amp is a dual 1/4" MALE blk/silver unbalanced plug(see photo below)
The amp is virtually my speaker. That part really doesn't affect it actually picking up vocal/recording stereo signal though.
I rebooted, the found new hardware wouldnt pickup, yet it had recognized it earlier before we had messed around with it. This has happened before! LAST TIME when it installed CORRECTLY, the computer recognized it AUTOMATICALLY AS "Delta 44 Multimedia Controller" or whatever it exactly stated. It picked up, installed on its own. Only thing i had to do was go to M-Audio and get the latest driver for it and it should've been ready. All the connections are as described.
SCREENSHOT of the Settings panel under magix2005
SCREENSHOT of the inside of my pc, where the 44's plugged in, SPLIT with a shot @ Sounds and Audio Device properties. It should show the 44 but nothing there. This is after the reinstall on the 44's pci card. Still not installed correctly for some reason. If I download the driver and run THAT program, will it THEN decide to pick up the 44 once ITS installed? But exactly which driver download update is BEST? Running XP Pro SP3.
This is where I currently stand. Where to go from here? Help.
[/quote]
