nate_dennis
So I've never really done any work on guitars, however, I thought that helping my dad out would be a good first project. His cheap Strat knock off is scratchy when switching P/UPs and occasionally the sound will drop out. I figured this would be a dirty switch/dirty connections. So I opened it up but I don't see any oxidation anywhere. None of the soldering seems to be undone, so I'm not sure what the problem could be. There is sign of wear where the switch moves across the "plate(?)" that holds the p/up connections. Could this be the problem? I hope That I am explaining things correctly. Any help you could give in diagnosing the problem and tips on how to fix it would be much appreciated. Thank you for all of the help you've given so far.
-Nate
-Nate
