miroslav
Cosmic Cowboy
I recently read some comments in a magazine about the need to use less low end in your mixes than in the past, since most people listen on smaller systems (iPods, computers, etc) rather than on some huge dance hall system with monster subs....
....but I'm not sure if it's really necessary to actually cut back on low end during the mix/master process more than what already sounds right to you on your studio monitors, in order to "prep" your mix for these small playback systems.
I mean...wouldn't those smaller systems by their design roll off whatever they can't handle anyway AFA low end?
I guess it's kinda the same (IMO) erroneous mix mentality where you do your mix on accurate monitors in your studio...and then you go and second guess yourself and adjust your mix to make it sound right for a car stereo system!
I'm thinking you can't worry about all the different playback system that are out there, so mix for your monitors, assuming they and your room are pretty accurate or you've learned how to mix in that environment...
...and then let the low end fall where it may (or where it can) on those smaller playback systems.
Thoughts....?
PS
I like a beefy low end...that 70's THUMP...though I don't get into that real heavy sub-low end like you might hear in hip-hop/rap music.
Thoughts....?
PS
