TelePaul
J to the R O C
Hi all. Just re-strung my new strat and now the bridge is at about a 20 degree angle to the body. I know this has something to do with the trem but it seems it was seated closer to the body before I restrung. Is it a problem?
Stretching the strings wouldn't have made a difference. If you put on a new set of strings and the bridge position changes, then there is a difference in the string tension. You say you didn't change string gauge, but did you compare all the string sizes? Just because two sets have the same high E doesn't necessarily mean that the rest of them are the same gauge. Also, hex core wound strings may have a different tension when tuned up to pitch from the same gauge round core string.Thanks so much for that man. I didn't change the string gauge but maybe I should've stretched them out a bit first. Anyways, I adjusted the screws till the bridge sat flush and it plays just fine. Thanks a mil, have no massive need for up-wiggle; I'm not Jeff Beck (yet!)![]()
Thanks so much for that man. I didn't change the string gauge but maybe I should've strecthed them out a bit first. Anyways, I adjusted the screws till the bridge sat flush and it plays just fine. Thanks a mil, have no massive need for up-wiggle; I'm not Jeff Beck (yet!)![]()
I was a "bridge flat against the body, dive only" for years during my blues/punk rock phase, but Satriani sort of ruined me.
I am wondering/thinking/asking if/how/does the setup of the tremolo strings (assume we have 3 in a vintage style tremolo) affect the overall tension. I mean if one uses thicker strings is keeping the tremolo string parallel to each other or keeping them in "V" shape is better?
ps. I'm sorry if I'm hijacking the post...
