F
fstrat76
Member
My Tascam 38, which I originally purchased with an M-35 mixer in 1985, I sold in 1994. I needed 16 tracks at the time and bought 2 black-face ADATs and a Tascam M-2600 24 channel mixer.
After recording with the ADATs for a bunch of years, I went all digital with a Tascam FW-1884 hooked up to various Macs running Logic Pro. Great stuff considering the space constraints I now have.
But something was missing. Maybe it was the sound, maybe the fun factor, I don't know. So last month I bought a Tascam 38 off of eBay. It was in mint condition.
I'm sure to no ones surprise, the unit arrived damaged in shipping. The feet were bent or pushed into the bottom, the capstan belt was disintegrated and rubber was all over inside. The left hub was low. It took a beating. Sad.
Luckily, the pushed in foot at the bottom pushed into an empty area on the frame and did not damage the circuit boards or other frame parts.
So I got the unit adjusted and its now in working condition. I baked some old tapes (Ampex 456 and 3M 226 and 996) and they played perfectly on the unit. I transferred some tracks into my DAW and was absolutely amazed at the sound quality I got even 20 years ago. I mean, its comparable or maybe even better than some of the stuff I did on ADATs or all digital.
Now I want to hook all my analog gear back up and start using it as well as my DAW and such. I cleaned up my M-35 and I'm thinking about tracking and hookup scenarios, and even thinking about digging out the huge M-2600 24 channel because it has phantom power (which I need).
The FW-1884 also has phantom power and I suppose I could route the insert send to the 38. Or I could buy a phantom power supply and hook up directly to the M-35, then on to the 38.
What I'm wondering is what others have done to maximize use of the analog equipment and tie it into a DAW. I don't have the cash for anymore outboard analog gear so for more than 8 tracks I'll be mixing in the box with Logic Pro I guess.
Does anyone have suggested hookups? Track on the 38, transfer to DAW, or track to DAW and mixdown on the 38? Or Both?
Should I bother setting up the monster M-2600 or just stick with the M-35 (or FW-1884).
I'm looking for your ideas or how you might go about it.
Also, I'm looking at getting some new ATR tapes. Does the 38 need to be re-calibrated for these tapes?
I've learned a ton already from this forum and looking forward to getting back to analog!
Thanks!
--Mike
Thanks!
--Mike
. Regardless you should check the bias. SM911 and 456 are bias compatible but there are always sliught variations, even between different batches of the same make and model of tape. Plus, again, it had a rough trip.
