D
Daniel | Davis
http://tindeck.com/listen/exga
Drums - Addictive Drums sent to multi-channel and converted to audio
Guitars - Single condenser, MXL993 pointed at 12th fret of an Ovation celebrity
Bass direct with slight compression from an old DigiTech pedal to round out some edges
Piano - Casio Privia stereo direct
CPU Specs: Macbook 2GHz Intel Core 2 Duo - OSX 10.4.11 - 1 GB 667 MHz DDR2 SDRAM
All into a Firepod and straight to Logic Express. No plugins, EQ, compression, nothing yet. Just some tweaking with panning and levels.
What do you think? Should I start adding the vocal tracks at this stage or should I start carving some EQ? What would be the next step you'd take in this situation?
edit: just tried some EQ. let's see if this made any difference:
http://tindeck.com/listen/idti
